BlackVue Parking Mode
Anyone using BlackVue in parking mode on their W205? How does the car battery hold up? Does the power magic pro unit operate as expected and not drain the battery?
The guy from blackboxmycar.com recommends using a brand called "multi safer," but when I did searches, I could not find anywhere that supplied this. He said he liked it because it handles the voltage cut-off better as well as the single ACC wire requirement...
This made me start wondering if it's safe to even use the power magic pro unit if he doesn't even recommend it...?
Please let me know real-world use...I'd love to record while parked, but don't want to mess up my battery.
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
The voltage cutoffs, etc are junk and will drain your battery, I found many articles on people having lots of issues.
I had the external battery pack, hooked upto switched power only, so when you are driving it charges it. (about 40 min driving will do a complete charge on it) and there is an app that connects to it, to tell you how much power it has, and how much it is using.
mrguitar (07-17-2019)
I've been using the Power Magic EZ OBD version for a few months with no issues so far.
The following 2 users liked this post by 4dr.no:
chrissy0874 (06-24-2020),
what were the main differences between the Power Magic EZ OBD and Power Magic Pro versions again? When you say "no issues" are you able to determine how your car battery voltage is being protected/preserved? Or are you just saying that you haven't noticed any issues? Thanks
Hey MrGuitar, I replied on my thread as well, I would NOT use the Power Magic Pro, use the external battery pack ( https://www.blackvue.com/power-magic...attery-b-124x/ )
Where did you mount the battery pack? It seems like the size makes it have to go under a front seat? That, or in the trunk somewhere...?
FLC63s, how long does the battery last on a full charge if recording in parking mode? If you were to leave the car parked for a week, would it last that long?
I had a blackvue installed in my 12 c63 with the module to auto shut off at 12.5v, have only had it for a couple months so not much experience but have not had any battery issues. Planning to have the same system installed in my 20 when it arrives.
There is NO WAY you are going to get a WEEK of charge from anything .... the top battery pack from BlackVue will give you max 24 hours (depending on options you set for recording - single or dual) , although you can link up multiple battery packs to give you more record time without recharge. Settings like motion activated or EVENT only recording will change the life of that as well.
arjy, you have the power magic pro set up or one of the other options?
I have attached some pictures, (descrptions are under neath each picture)
One thing I wanted to point out, as I have seen others do this (which is stupid IMO) you DO NOT NEED to cut your window tint !!!
My rear view camera is mounted on my window / tint , and you can see the view from the camera is fine , even at night with the night vision enabled.
(for the love of god, do not cut a hole in your tint , or allow anyone to say you need it)
Outside View (I have LIMO TINT) on all my windows, so its hard as hell to see it unless you are looking for it.
Close up, of harness and placement.
Front Camera from Passenger seat (close view)
Rear View Camera (you really cant see it from driving)
Rear view camera from looking up at it in back seat
Video snapshot out FRONT WINDOW
Video snapshot out REAR WINDOW and LIMO TINT
The following 2 users liked this post by FLC63s:
Looks clean. BTW, regarding the tint, I wouldn't poke a hole in it either for the camera to see through, but how does the camera mount hold up on the tint (i.e. since it's not attaching to the glass anymore)? No issues there at all?
Also...turn on your public cam so we can watch! Hahaha
front camera is the heavy one
On the front camera, it would NOT be mounted on the tint strip, as it should NOT be that high up. If you mount it directly under the rearview mirror console (on windshield) it is perfect.
I also should have mentioned that I'm thinking of tinting the whole front window since i want to keep the heat down...would there be any issues with mounting on tint in this case?
LOL
As for the tint, and the Camera mount, I would let the TINT cure for a while before mounting the camera on it, or to play it safe, then have them cut the square area where you will mount the camera.
yeah i may end up not tinting the entire front, in which case, issue solved. good idea about curing it, if so though.
i haven't gotten the camera yet...what is the mounting methodology? is it just a sticky thing? suction cup? etc.
its sticky 3m tape on it.. you just line it up, and peel and stick... I lightly stuck it on the window (enough that it wouldnt fall) then went outside the car and looked at it straight on, to make sure it was in line with the middle of the hood, then push it on real good.
mrguitar (07-18-2019)
Just reviving this posting.
I just installed a Blackvue 750LTE - 2 Camera in my C63S and I have a magic pro for power. What are the best settings for the camera to maximize battery life without an extra battery, and also maximize the resolution of the video?
I have a couple of issues I've encountered so far:
1. Someone hit my car, but I didn't know until the next day, but the camera already rewrote over the footage on the cloud (5GB) and on the SD card. Can you get more than 5GB on the cloud?
2. Another time someone hit the car, and even though I have the video resolution set to highest, I can't read the license plate because their car is moving too fast and the video is pixelated and not good enough to read.
3. I've turned on time-lapse for parking, but it drains the battery in 1.5 days. Is it better to turn off the time-lapse option?
Cheers
Cheers
Cheers
Cheers
on items 1 -2 , you need to set the " collision " event detection to LOCK the file, this way it will NOT overwrite any files that are created from an event ( you can set the events to be "impact, motion detection, etc "
Make sure you have your motion detection area setup, otherwise it will prob just keep recording non stop.
Do you have the LTE antenna as well ?
With respect to item #3 , this all depends on what type of monitoring you are looking for.. I have mine set to record on motion, or impact (in parking mode) and it records 2 min at a time. (on 4K)
When a impact is detected, it buffers 30 seconds prior and records and "locks" that file so it cannot be overwritten.
