Code P0455
If you are not handy, you can buy a replacement valve. They aren't very expensive.
If you are not handy, and are broke, you can put tape over the CEL.
This is why you should never top off. The liquid gasoline washes away the grease and makes the rubber seals stop working.
I was on a road trip and found it annoying enough that the CEL would come on (cat converter errors) and figured out how to reset them while I'm driving.
If you had a problem with the gas cap, you probably would see it in the condition of the o-ring. Odds are you need to service the evap control valve as I described earlier.
