Drivers Assistance Package
Hi guys. I am researching on buying a W222. Are there any differences between the drivers assistance package in terms of improvements over the years? Specifically 2014 vs 2015 vs 2016 vs 2017 vs 2018 years?
Thank you
Thank you
Received 3,704 Likes
2019 C63CS
Yes. Don't know specifically about individual model years, but there are generational improvements between the PFL and FL models for example. All the assistance systems are continuously being improved and as opposed to Tesla, MB doesn't make those improvements available as OTA updates for existing cars. I'm sure there are software improvements from year to year, but at least there are improvements during the FL. MB has been introducing the latest systems with the S Class and then trickle it down to the other models. The W223 has the latest generation and the FL W222 is one generation down. I have the same system in my FL C63 and it's noticeably improved over the previous generation. There's perhaps too much to go into in terms of individual improvements, but overall the newer generation systems just work a lot better.
I cannot get to the site you posed C Swenson, I tried to sign up for an account and was denied told it was for members of the media. For the original poster, I have a 2016 S Sedan with all driver assistance package. The distronic cruise control works fantastic, better than my wife's 2021 Nissan Leaf (only comparison I can make directly) but the lane keep is not nearly as good as the Leaf's Nissan Pro Pilot. While Tesla is probably the best right now they are getting bashed pretty hard even TV commericals asking congress to get them to shut it down due to issues.
2015 S550 4Matic, 2014 ML550
If you want to try copying and pasting into your browser the address is:
https://media.mbusa.com/channels/cha...8e2300cd4d-qrg
2019 C63CS
Quenthel (04-21-2022)
Try this:
S-Class Quick Reference Guides
I had a W221 and now a FL W222. One of the first FL. It came without Active Lane Change Assist, wich ive read, comes with some really, really scary affects. Like abrubtly steering to avoid a non-excisting obstical. So im glad it isnt ecuiped with. Mine has the Distronic Plus (code 233) /active lane assist (DTR-Q?), stop and go with "extended traffic jam function" (K33) and Active Speed Adjusting when following a a planned route (code K34) in the Comand route navigation. The latter wasnt available on the W221. And was one of the reasong i wnt foir this package.
Noticely better than the W221 is when someone pulls in front of you after he/she has passed you and pulls quite early to the right, just about hitting you fron bumperlip. The W221 slightly went off-throtlle if this happened. Thats gone. Is sees also better throughout the vehicle in front of you better. So if a trafficjam is ahead of the car in front of thát car, so quite ahead, it sees that allready and gently decellerates in a gently matter. IOW is sees the trafficjam allready, even if its not quite as obvious for you as a driver. Bought the car with outdated maps and updating those improved the suddon and with no obvious reason braking, significly. But at random, it sytem sees "danger" of some sort and goes off-throtlle or brakes. With absoluto no reason. Tipping the pedal overules that decission and it accelerates to the previous set speed. But honestly, its scary sometimes. The brakelight come on and cars behind me think i brake in the middle of the highway with no reason at all..
The butttons on the steeringwheel are now common. I absolutely hate them and the sublime stock-type cruisecontrol was thé best system ever made in my opnion. Sometimes i accidently trigger the Resume function so the car accererates towards the previous set Distronic-speed. And i mean fast! Imagine driving 30mph and before having it set at 100. And by turning the steering wheel or some other reason you accidentaly touch that Resumebutton..That will scare you believe me.. I turned of the Street Sign recognition also because that function has so may flaws and its more or less useless. When it detects a 20mph sign in the vecinaty traveling at a highway set at 70 it will just slam on the brakes...perfect! The Active speed adjusting evenso. Itll brake too soon when entering a corner of roundabout. Just way to early. And sometime at the last moment. And driving with the Auto-pilot on a roundabout is just not i thing a car should be doing. Its overkill. Nice function in the Facelift-model is a overall pretty darn accurate warning of a "end of a trafficjam ahead", eventhough you dont have route programmed in the satnav. Ill warn you of a trafficjam ahead so you can expect danger. The Active speed ajusting isnt active when traveling a route programmed in Android Auto via Google Maps, so in this way you you can avoid the mentioned "flaw"when traveling via the Comand entered route. Stop and Go in trafficjams is a pretty good system. It deactivates after a standing time more that 30 seconds or so. Tipp the gaspedal and ist actives it again. Auto-pilot assist activates a warning to wiggle the steering just a bit or squizing the wheel with your hand firmly, giving the impression to the sytem youre still paying attention.Wiggling the sterring wheel just a degree also wakes it up towards the 15 seconds warning. This could be deactivaed by Viadeo-Monaco. If you do noting itl start beeping and eventually pulls to the side and activates E-call and the hazard warninglights. The system will pull the steering a bit away from a obstical if an head on is almost ocuring. Once i drove on the AutoBahn traveling 240+ and some AH yust pulled to the left, he misinterpreted my speed, i SLAMMED on the brakes and a collission was almost inevitable. Just at the last moment when i almost hit him, the darn W222 pulled the steering a bit away from him steering gently the most it could to avoid hitting him. Not to much so forcing me in a barrier, but really helping/thinking/steering away from his car. I remembered it like the day it happened. I couldnt interveighn in that decision and even when i would it kept avoiding that idiot. It saved my life. The Lane Keeping thingy, auto pilot thingy and alle safety featured it comes with are possibilaty to shud down of deactivate them by a switch. And when restarting hte car, there still in the Off-postion. TI like that. They should have done that with the Start/Stop function but thats another topic. Autopilot is nice to open a can of Cola but in my opionon the car waves too much from richgt to left. Its like swifling between 2 lines too much. I only use it as a add-onn. Steering myself keeps it more i a straight line that a computer. And there's the trust stinghy...going 130kph im rather myself doing the decisions overall. Overall its a quite nice gimmick but 99% of the time im doning it the old fashioned way. Especialy in downtown areas.
2019 S560, 2022 Audi S8
The only thing in my opinion that went downhill is the speed limit detection system. The pre-face lift models up to 2017 used GPS based speed limit info. They switched to a camera based system in the 2018 and up models. I prefer the GPS system as many, many times the camera system misses "seeing" the signs due to things such as a big truck blocking the view as I approach the sign.
2019 C63CS
S560 Long 4Matic (DE) MY 2018
I drove for a bit at ~190kph on the Autobahn with some light traffic the other day. It wasn't as bad as the 237 one and the car sure is stable enough even at these speeds, but I always had to be VERY mindful of people changing lanes to the left (in Germany people usually don't flash the turn signal and wait a bit, they exit as soon as they flash the turn signal. It's not illegal, but it's idiotic). Generally speaking I had to have my wits about and be ready to decrease my speed way sooner than I anticipated, exactly because people really underestimate how fast you are coming from behind. 130-160 is fast enough without fatiguing me too much.
Regardless, all the assist systems work well enough for me but they are not perfect. The lane change will sometimes fail to do its thing. The speed limit signs fail to be recognised some times (or it won't recognise conditional speeds). Lane assist on my MY18 model sometimes steps on the lane by itself (and then it complains...). I do keep them all on however, because they help a lot when I travel long distances but I never take my mind and attention off of them.
Second very important thing to me that drives me completely crazy is this f... breaking based on the route.. if you keep it on, the system shows another icon with the arrow heading down, letting you know distronic is now breaking bcs of the road... when you completely turn off this stupid thing it should be fine and not break in corners on highway but there is some second stage of it that also noone of my cars does. If the corner is more sharp the car with activated distronic will stop accelerating... i can see it on the actual consumption bar that the car just stops accelerating... all my other cars can enter a corner even in 190 if the distronic was set on 190 and leave the corner in 190kmh... this car enters a corner in 180kmh and leaves it 140kmh and start again accelerating after the corner even when the breaking based on the route is turned off.. it drives me really crazy i know what i am doing and when i want take a corner in 190 on distronic is absolutne unacceptable for me to let my car slows down without my command PLEASE tell me someone there is a option to disable this... as far as i observe this special function it depends on the G-Force meter where it is.. also when i drive 140 on distronic on empty highway and i just shake the steering wheel that the g-force meter feels it, the car stops accelerating or holding the speed
I would do anything to disable this please tell me i am not the only one who really hates it...
and please you said you can disable something with vediamo.. you mean the alert that you dont have hands on the wheel? it can go completely off? whats the result? infinity autopilot?
And as you said you feel on autopilot the car is shaking from side to side too much u are right... but again, both my e class are much more in the center of line without going from one line to another...
thanks in advance to anyone who can help me with at least on of this things.. i drive a lot, like really lot, sometimes i feel like i live in the car and i need this things working as i am used to
