2017 CLS63S Issues
maw
Can PM videos if anyone is interested. Thank you
Where you should draw the line is with LIMP MODE: this can lead to fatality in rush hour traffic.
Get this worked on by your local MB experts:
- Start with a chassis comprehensive scan
- Focus on most unstable CAN Modules
- Deal with marginal voltage issues
When the warranty expires is when work stops regardless of known pre-existing defect.
Then you can experiment with your spongy throttle out of warranty.
nother follow up from me, did this start happening at random for you or was it always there? Mine consistently happens under light load and right at 2k RPM
It's not rocket science to fix BUT it may soon become a money pit opportunity hence got Carmax traded.
This reads like a basic CAN disruption.
Tranny is forced to limp mode when gear selection goes missing Or gear selection goes blank when TCU gets unstable.
Nearly no big deal: this does not call for a tranny rebuild job.
If you don't have an MB scanner someone is gonna need to identify the root cause without replacing too many working modules.
Your summary captures this well :
- PRND display goes missing
- Engine throttle limp modes
- MFK - EIS lost COM... CGW??
I can see this repair ballpark from 1 to $4k.
This CAN disruption could be as simple as a low battery charge... few techs want to diagnose a cheap warranty repair. Next time may be an ECU plus couple injectors...
Even if you could pinpoint the exact cause yourself, this would hardly alter warranty course.
I'll keep the thread posted when I get a confirmed diagnosis or fix. If you see an AMG on carmax with about 60k miles, it probably needs a trans LOL.
Were the PRND + Limp mode present before or did this show up recently ?
It may be the newly rebuilt TCU module has issues. Faults would point that way.
- 1 - Diagnose the faults from a chassis report.
- 2 - Test the top suspects before rushing to conclusions.
Provide a precise list of issues to help guide work order while you can:
- MFK drops COMS with EIS
- missing PRND display
- Limp mode near 2kRpm
