Water pump gasket leak
2013 80000 miles. Water pump gasket is dripping slowly . Coolant is slow to go down . Do I wait until it gets worse? Will it one day get real bad? Do I replace pump and pulleys ? Or just the gasket ? Do the pumps themselves fail?
I would budget out the whole shebang and get it all done at once: new WP, gasket, t-stat, belt, rollers, tensioner.
You'll have to get in there sooner rather than later for the other components, might as well save yourself the headache and double labor cost.
Not sure on the gassers, but the diesels originally had plastic impeller water pumps that were prone to failure; an updated part has metal impeller, make sure to get that one. I'm pretty sure a new WP comes with a new gasket included.
The sky is the limit; the question is how lucky do you feel?
2013 GLK 350 4 matic
Most water pumps have a small hole to allow water to drain out when the pump fails. It would look like gasket leak.
I would change the pump ASAP before it fails completely, and change belts extra as they are roved anyway.
calder-cay (05-16-2024)
2014 GLK350 base model ; 2001 E320 base
Personally, I have no idea if the GLK water pumps have the weep hole - would be a good thing.
Bill F (05-16-2024)
