thermostat replacement 2014 ML CDI
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
Hello All.
I wanted to replace thermostat (it is one on top of engine) but I was stuck in removal process. One (long) screw is impossible to remove due to lack of space (hitting directly to gas line). I removed turbo pipe to get more space but I got nothing.
What is the trick to remove long screw ? I don't see screw what it should be remove to get access to move gas line which it is going directly to filter ...
S
S
2013 ML350 Bluetec
can you just loosen the screw all the way so it isn't attached to the engine anymore but leave it in place on the thermostat as you lift the thermostat out? Obviously you'd want that same screw in place on the new thermostat before putting the thermostat in place...
I've had to play that game with heads on my duramax and air filter housings on my ML.
Trust me ..I have tried every possible screw around to lose and get angle to take out. Also, I followed video on Youtube (search:
'German engineering'
Thermostat "Wechsel" MERCEDES-BENZ 350 CDI - V6 in 25 Minuten als Leihe !!
But the key point of taking screw out is missing ...I am determined to replace this but I am not sure how many more parts I need to remove to get it out.'German engineering'
I cannot believe that I am first one who is replacing thermostat Should be some trick (wisdom) how to remove long screw as per above video.
It is summer but winter is around corner
A
A
