How to check the oil level
Can not find my manual and don't see it up in the stickies nor can find any Info on YT. It's a 2014 E63s and don't see any dipstick either.
Tons of Info on oil change and resetting the service light but nothing W212 specific
I thought I found the dipstick on the driver side towards the firewall in Blue color but the manual says on the passenger side, may be not model specific.
So can anyone please post a picture of the dipstick location and or the cluster way of checking the oil?
Whats the proper way of checking the oil, car warmed up, running or what?
Received 1,994 Likes
That's your oil dipstick ... drivers side by firewall
There is only one dipstick and nothing smells like motor oil, except motor oil. Pretty sure these transmissions dont have a dipstick from the top. Filling them is done through a one-way rubber valve in the trans pan with pressure.
Pull it - it's probably what you are looking for.
Received 2,419 Likes
PFL205.064 with M276.823
If it is the first pull after driving (say right after turning of engine or been sitting), it being dry could be due to the airtight seal, it is a common characteristic of MB engines and their dipsticks, just do another pull and you will see oil even if it is cold. That said, vehicles with dry sump also requires a different way of measuring.
PeterUbers (Yesterday)
