2014 Mercedes Benz GLK - Front End Squeak - Need Help Identifying
I recorded a video and talked a bit about what was done so far. Any help appreciated!
2014 GLK350 base model (active) ; 2001 E320 base (retired)
I'm not sure which "sound" we're looking for ... I hear three sounds that someone might wonder about.
Also, you mentioned , "it varies on temperature" ... what temperature... outdoor weather temp or the temp of the engine??
Thanks for the reply. Time in the video for the sound is at exactly 0:55, 0:58, 1:01 and 1:05. I am accelerating then hitting the brakes. When I hit the brakes is when the squeaking sound happens, but also it happens when I go over bumps as well, so it's not related to the brakes. I mean the outside temperature
My first guess is the most common "wear failure" in the GLK's front geometry - the "compliance bushing" on the "upper" control arm (though it's clearly very low - confusing terminology).
Anyway, your first clue will be the signs of the dark fluid seeping out from the fluid-filled bushing, and then by the movement.
Anyway, here's a video I did on my 2012 "project" GLK, showing both symptoms clearly:
https://www.youtube.com/watch?v=5_vZBH_FHOs
I didn't see any signs of leakage (maybe it had all been washed away), but both of mine were bad, and the left one was making a "clunk" when you hit a bump just right.
The clunk when you release the gas ? If you coast then and hear a clunk when accelerating its the front driveshaft, what I really hear is the motor . Did you test all suspension parts to see if they are loose with a prybar? I had a noise, I ended up replacing everything and the driveshaft, no more noise !
