2014 Mercedes Benz GLK - Front End Squeak - Need Help Identifying
Old Jul 3, 2024 | 02:05 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
I recorded a video and talked a bit about what was done so far. Any help appreciated!
Old Jul 3, 2024 | 02:42 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I'm not sure which "sound" we're looking for ... I hear three sounds that someone might wonder about.
Also, you mentioned , "it varies on temperature" ... what temperature... outdoor weather temp or the temp of the engine??
Old Jul 3, 2024 | 02:47 PM
300SE1993's Avatar
Thanks for the reply. Time in the video for the sound is at exactly 0:55, 0:58, 1:01 and 1:05. I am accelerating then hitting the brakes. When I hit the brakes is when the squeaking sound happens, but also it happens when I go over bumps as well, so it's not related to the brakes. I mean the outside temperature
Old Jul 3, 2024 | 03:55 PM
habbyguy's Avatar
2011 GLK 350 4Matic
My first guess is the most common "wear failure" in the GLK's front geometry - the "compliance bushing" on the "upper" control arm (though it's clearly very low - confusing terminology).
Anyway, your first clue will be the signs of the dark fluid seeping out from the fluid-filled bushing, and then by the movement.
Anyway, here's a video I did on my 2012 "project" GLK, showing both symptoms clearly:
Old Jul 3, 2024 | 04:03 PM
300SE1993's Avatar
https://www.youtube.com/watch?v=5_vZBH_FHOs
That is interesting. I had no idea those were fluid filled. I was under the car today and did not see any leaks from either of those bushings and could not hear anything when I moved them around a bit.
Old Jul 3, 2024 | 05:08 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I didn't see any signs of leakage (maybe it had all been washed away), but both of mine were bad, and the left one was making a "clunk" when you hit a bump just right.
Old Jul 4, 2024 | 12:39 AM
Mmr1's Avatar
2013 glk 350
The clunk when you release the gas ? If you coast then and hear a clunk when accelerating its the front driveshaft, what I really hear is the motor . Did you test all suspension parts to see if they are loose with a prybar? I had a noise, I ended up replacing everything and the driveshaft, no more noise !
Old Aug 29, 2024 | 11:36 AM
300SE1993's Avatar
Update: Turns out it was one of the bushings on the lower control arm that the fluid leaked out of. Perfectly silent now.
Old Aug 29, 2024 | 09:55 PM
droptopchevy's Avatar
2010 GLK350 4Matic
That is the exact part the video shows.
Old Aug 30, 2024 | 03:38 PM
techrick's Avatar
2012 GLK350 base model
Originally Posted by habbyguy;[url=tel:8995874
8995874[/url]]My first guess is the most common "wear failure" in the GLK's front geometry - the "compliance bushing" on the "upper" control arm (though it's clearly very low - confusing terminology).
Super helpful information and video! I have some noises and will be checking these compliance bushings.
