Front Left Passenger Seat Adjustment Not Working
Old Yesterday, 10:51 PM
Skitspit's Avatar
C220 CDI
I've had a problem with the front left passenger seat working sometimes and other times not working. Its finally stopped working completely. I've checked the fuses for seat adjustment and I'm missing fuse No 63. don't know if it always has been missing or not. I've also checked for code and have gotten this one. Does anyone know what the issue might be so I can try to fix it thanks.
Scanned car before clearing codes
After clearing codes and rescanning
Old Yesterday, 11:40 PM
TimC300's Avatar
Guessing you have a right hand drive vehicle. Im not sure if the fuse locations are the same. When I look them up there is a fuse for the "front passenger seat control unit" in the fuse box next to the steering wheel, #126., then there are fuses in the trunk, #44 and #45.
Heres the fuse diagrams i was looking at: https://fuse-box.info/mercedes-benz/...uses-and-relay
have you checked under the seat to make sure nothing is wedged in there preventing it from moving?
If it were me I would use a multimeter to test the harness going to the switch for power. Inspect the harness and wires, inspect the ground connection. if its getting power then its probably a bad switch.
Old Yesterday, 11:46 PM
benzuserjee's Avatar
A 200 Sedan
check the ground connection too. a bad ground can cause all sorts of weird electrical issues.
Quick Reply: Front Left Passenger Seat Adjustment Not Working
