Part of my headlight won’t work
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1242x1172/img_3576_2f8d583357ed54d65813edcd8486d45e2a1da86c.jpeg)
This part of my headlight does not work I recently bought the car so could it just be the bulb if so could someone send me a link to the exact part I tried looking but these headlights are a little confusing thank you
Received 3,534 Likes
MY'14 W212 M276 3.5NA @60kMi
How did you figure these bulbs are bad ???
Have you tried with HEADLIGHTS HIGH BEAMS ON ?
Do not stare at light bulb directly to prevent retina eyes damage.
High beam circuit...
All right, your chassis has a 2x non-working high beam incandescent bulbs.
The bulb power is controlled by F-SAM acting upon messaging from SCM stalk sensors.
Usually headlights are fused individually L /R... so missing both highbeams is unlikely a fuse issue!
-- The best way to diagnose solderless SCM module is to test using a compatible scanner to exercise it live.
-- You will easily read activation status under 5mn without any disassembly.
-- You will be able to toggle lights on/off
Let us know test results.
BenzV12 (07-24-2024)
