my blindspots don't work anymore. Where is the location off the sensores?
Old 07-26-2024, 02:01 PM
Tab007's Avatar
w212 E220
my blindspots don't work anymore it gives errors. The question is where are the sensors on the sides so I can check if they are dirty or covered? so i can clean them and see if that helps. It may also be because moisture has gotten in since I have washed the car very recently.
Old 07-26-2024, 02:19 PM
W205C43PFL's Avatar
Received 2,654 Likes on 2,257 Posts
They are behind the rear bumpers on each side. Located close to the rear side parking sensors but from the inside.
CaliBenzDriver (07-26-2024)
Old 07-26-2024, 04:39 PM
Tab007's Avatar
w212 E220
Do you have any picture off that.
Old 07-26-2024, 04:57 PM
W205C43PFL's Avatar
Forum member konigstiger has a great PDF on this:
https://mbworld.org/forums/attachmen...pot-assist.pdf
Old 07-26-2024, 04:58 PM
W205C43PFL's Avatar
Found this video on youtube
Old 07-27-2024, 08:04 PM
CaliBenzDriver's Avatar
Received 3,584 Likes on 2,386 Posts
MY'14 W212 M276 3.5NA @60kMi
it's a lot of fun to remove bumper but is not necessary to access the BlindSpot Modules.
Save time look at it from under... wear plastic safety glasses for all the dirt falling down in your face.
The killer is leaky harness connector... BS Module is 100% watertight besides unprotected input connector.
Old 07-27-2024, 09:16 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
There are a couple good threads about this on here
Here's one https://mbworld.org/forums/e-class-w...lind-spot.html
I did not remove the rear bumper. You can access the sensors from underneath. Be warned - removing the connector is difficult as it will have "welded" itself to the sensor over the years
Good luck
Quick Reply: my blindspots don't work anymore. Where is the location off the sensores?
