Rear Radar (Blind Spot)???
Thanks all
If above is true you may have a problem with the AUX battery. Lane keep and blind spot assist are separate functions. Lane Keep works from the camera in the windshield and does not use radar sensors so them both going out at the same time is probably something else than the radar sensor. It could be a coincidence that both go out at the same time but not likely. Scanner may be able to tell what the problem is but if it does not then look at the AUX battery condition.
I have a 2010 E550 and I had this same problem when the outside temperature wend down during winter time and the AUX battery got weak. Re-starting the car cleared the errors as the engine after one start fired up easier. The fix was to replace a fist size AUX battery that my car has. Yours is probably different design but these are the same symptoms when the AUX battery goes weak. In my car I also lost the Distronic function when this all happened.
I did not have this trouble yet (knock on the wood) but I read that those radars are prone to corrosion damage.
Clean them up, unplug, look for green crusties.
I can try to have a closer look at that control module if someone WISe would please show us where it is hosted + wiring schematic
I'd guess it is located somewhere near the front... under the dashboard -or footwell side??
My bet is... this safety related module does have professional grade but wiring issues.
My 2x front side RDU sensors invariably report being affected by "external noise" but appear to work.
The crusted rear sensors are on my list to visit with silicone calk before rain contamination sets in.
Let's see how we can sort this out.
TOGETHERNESS :
"BlindSpot and LaneKeepAss. disabled".
What do they share that makes them go wonky simultaneously ?
The sensor has undergone several revisions over the years... if you want to avoid the possibility of needing to code them, then replace them with the exact same P/N, along with other designators on the sensor (HW and SW). See here: https://mbworld.org/forums/e-class-w...placement.html
Geat files you posted.
Without a scanner is there any way to diagnosis if it is a CAN problem or 2 rear sensors?
Both sensors are inoperative and both sides don't detect a car in the rear. Everything else on the car seems to work.
The left driver side under panel was serviced 1 month before blindspot when inoperative (scrapped bottom on parking garage -- too steep between floors).
The sensors looked fairly clean. Sprayed under bumper if dirt between sensor on bummer cover. Wait 3 day to dry area before turning back blindspot assist. Still no go.
Dave
2012 E350 4-matic 4 door.
WDDHF8JB7CA638461
Will salvage on be at end of its life cycle ?
Thanks!
So, just 2 days ago almost side swiped a truck next to me when changing lanes. Had my blinker on but no warning from blind spot monitor.
The triangle comes on yellow with very slow speed or stopped but it does not come on with someone in blind spot while driving. It does seem to work on the passenger side, i.e. the triangle comes on yellow when someone is in the blind spot but it does not work on the driver's side, which is the more important side due to the mirror being straight glass.
I do not have any error messages or warnings at all. Checking with my iCarsoft MB II does not help at all either so I'm thinking if the sensor simply fell off of the bracket and is pointing in direction it cannot see any vehicles in my blind spot...?
Can I access the sensor without taking the bumper off of the car? konigstiger posted nice documents, as usual, but there is also instructions for removing the bumper.
Daily is $20
