SL/R231: oil change, suck out from top
Old Yesterday, 07:55 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
on sl 500 , 550 can you suck out the oil via hole where measure level oil? or is that not good ?
Old Yesterday, 08:28 AM
W205C43PFL's Avatar
Received 2,565 Likes on 2,180 Posts
Yes, as long as you confirmed you have a dipstick: https://mbworld.org/forums/c-class-w...il-change.html
Old Yesterday, 09:57 AM
JettaRed's Avatar
Received 1,639 Likes on 1,222 Posts
Actually, the SL500 (M113) engine has a dedicated tube for oil extraction. It does not use a dipstick, but rather the oil level is electronically measured.
WRT extracting through the dipstick tube, that is the specified way to drain the oil for most engines with the oil filter on top.
Old Yesterday, 02:00 PM
rmorin49's Avatar
2015 SL400; 2019 X5M40i
Perhaps, but I disagree. I like warming the oil up, then removing the panels and draining the oil from the crankcase. This assures you get all of the oil and any debris particles. JMHO but if you have access to a lift as I do, this also allows you to perform a good inspection of the entire undercarriage.
Also, I have the V6 engine if that makes any difference. It does have a traditional dipstick.
Old Yesterday, 03:25 PM
W205C43PFL's Avatar
Originally Posted by rmorin49
Perhaps, but I disagree. I like warming the oil up, then removing the panels and draining the oil from the crankcase. This assures you get all of the oil and any debris particles. JMHO but if you have access to a lift as I do, this also allows you to do an good inspection of the entire undercarriage.
Fair enough, WIS calls for top extraction though for the M276 at least.
The following 2 users liked this post by W205C43PFL:
JettaRed (Yesterday), rmorin49 (Yesterday)
Old Yesterday, 03:34 PM
rmorin49's Avatar
Understood and probably what the dealers do as it is far less time and labor involved.
Old Today, 07:10 AM
this page is R231 page , dont mix up with R230
Old Today, 07:14 AM
did it old fashion way , lift up car and drain it , took less than 20 min all operation , very easy on this engine model do it.
Old Today, 07:37 AM
Benz_Pro's Avatar
2003 sl500, 2003 c240
Both methods are completely fine if your vehicle comes with a dipstick. However I find inconsistencies with how much oil is needed to reach full depending on if I drain using drain plug or oil extraction. Just make sure oil level is correct after finish. It is easier to use drain plug to ensure full drain. Using oil extraction tube you may not actually push all the way down to the bottom, or your extraction tube can curl in bottom of pan and not extract all the oil properly.
Old Today, 07:56 AM
JettaRed's Avatar
Sure. I always adjust the extraction tube as I approach the end of the draining. I've always gotten 6.5+ liters from my engines using the suction method. Capacity is 6.5 liters for the M276, but I always fill to the top of the limit on the dipstick.
Old Today, 08:43 AM
W205C43PFL's Avatar
Good to hear : )
rmorin49 (Today)
Quick Reply: SL/R231: oil change, suck out from top
