ADS Fluid
ACS Fluid
I was wondering which is the correct ACS fluid to use and whether there is a good write-up how to change the fluid (besides just replace what is in the reservoir...).
Thanks!
Thanks!
BlownV8 (09-02-2024)
Nailed it!
Where the circle is is for ACS fluid, and where the arrow is is where the blinker fluid gets in.
The blinkers will give a nice new shine when you add it there!
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/275x183/c5acd133_0886_4762_8c62_b39656e2ddfd_1207f6bb2c9845b9a5c1eb084d76ff55163a3806.jpeg)
P.S. I corrected my typo! Sorry for that.
I just thought to replace the fluid as it probably has never been done.
Received 1,078 Likes
E55, GLS450, GL63, GLE350
What do you mean you heard it's quite a bit?
Can you explain? "changing to a 550 that alphas ACS and the off-road package"
I'm not really following you. So, you do not have active curve but you are thinking of changing the active curve fluid in a 550 you are looking at buying?
you're right, I'm getting rid of the 450 and will purchase a 550 that has ACS.
I read somewhere that it takes 11 quarts hydraulic fluid to fully replace.
But so far, I have not yet found the recommended service interval and a description of the procedure.
Thanks for the help!
Hi,
That's because MB probably lists it as a lifetime fluid which means the max time they will warranty the car. It will spring a leak before or around 100k miles and the repair is not cheap. The system does work well but, if you want a more reliable vehicle, I advise against the option. Again, it does well at keeping the big girl relatively flat around curves, but you are in a huge SUV so there's that.
Any ideas where these leaks typically occur by chance?
Anyways, good I have an extended warranty (hopefully one that actually pays 😄
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
