Fluid leak down to passenger area
Mercedes E 250 2010
Today i was just checking down side of the car (W212 E 250 CGI,2010 year). I found few drops down which I cant identify properly but I am sure it is not water. When I checked body parts from down I found down body of passenger side is like wet as in this Photo. This just down to coolant tank, i am using water as coolant because I have changed some parts recently and mechanic advised to run with water as coolant for few kilometres. Please go through the photo also and it will be helpful if someone can diagnose it.
Received 3,817 Likes
MY'14 W212 M276 3.5NA @60kMi
You may want to check other fluid levels for good measure.
BTW: straight water is going to mess up your water pump seal and coat everything with lime.... drain the water, replace with specific MB coolant ASAP.
The following 3 users liked this post by CaliBenzDriver:
Do NOT use common water on these cars. It is distilled water with the PROPER coolant, not ANY coolant.
May I ask what experiment is your mechanic running on your vehicle? I am sure forum members would love to learn from your mechanic.
Now the leak. The only fluid running behind the dash are AC refrigerant, and coolant through the heater. Fluid on the passenger well usually come from:
1 - clogged sun/pano roof drains
2 - leaking windshield seal
3 - disturbed and clogged AC drain
4 - worn/torn door seals and driven over water, or heavy rain
5- leaking heat exchanger?
The following 2 users liked this post by JCM_MB:
CaliBenzDriver (09-03-2024),
pierrejoliat (09-04-2024)
Mercedes E 250 2010
Mercedes E 250 2010
today i checked engine side also, there is some fluid in the engine covered area down.i think a chance of steering fluid leak, there is sound variation while fully turning steering
the steering oil capacity is like 1.5Qts so any small leak will show easily by looking at the steering pump tank with engine OFF.
Have a look soon, steering is essential.
Received 4,652 Likes
M271.8 EVO is your engine correct ?
Here is that engine GUARANTEED to break and leak parts/region for coolant and engine oil.
The same thing happened to my friend C200 W204 which uses the same engine.
01.
02.
03.
O-rings of coolant and engine oil at turbo.
04. The engine oil filter + cooler combo housing and the plastic pipe
In Malay language, but it will show the broken parts
Item 3 and item 70 to be replaced.
05. If you tranny oil cooler is a combo with radiator , This will happen sooner or later, but I can't predict when :
https://mbworld.org/forums/e-class-w...ure-point.html
06. The power steering pump o-ring can leak and will leak as it aged.
Good luck with the repair..........
01.
02.
03.
