SL/R230: Roof flaps problem
Roof flaps problem
Hi,
I replaced the the actuators and tightened them.
But as soon as the roof opens, the flaps hang loose. If I tighten again, every time they are straightaway lose again.
anybody familiar with this problem?
thanks
thanks
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
How did you tighten them? If your car still has the original brackets in the flap hinges they are probably bent, allowing the gears to jump tooths. MB sells improved (stronger) ones at reasonable cost. Lubricate those hinges when you're at it, I was surprised how hard it was to rotate them while their gear was free.
it was hard to rotate them indeed. Maybe I should do it all over… I will do that and keep you posted
i disassembled the whole mechanism. All gears look fine. Still while operating the roof, the trunk opens en the flaps stop halfway.
if I then push on the upper 2 micro switches with a screwdriver, I am able to close the roof again.
any idea what can be something else to check?
thanks
The motor and flap gears have to be in sync or they won't have the proper range of travel. You might need to reposition the flaps.
Frederick NL (Yesterday)
Sounds like are purely mechanical thing: the flaps need to do the same thing at the same moment. Did you create incongruence between them while replacing the brackets?
but every time when I open it, the flaps stop halfway.
Are you able to post a clear photo of your right hand front lock, at the front of the roof panel? Is the black plastic 'finger' undamaged and stable?
