GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
Acceleration hesitates at 15-20 mph
Old Yesterday, 07:13 PM
rabad2008's Avatar
gl550
During traffic when I slowly accelerate from 15-20 mph the car hesitates, but if i accelerate fast the car does not hesitate. Has anyone ever come across this issue?
Old Yesterday, 07:33 PM
Baltistyle's Avatar
13 s212 63 p30. 03 s55amg. 06 LX470
Take a look for oil in the harness. Have you done this, or replaced cps and magnets? If you can, log the car for misfires, related to coil packs. Change the bad coil pack around and see if the misfire follows. Replace if that’s the case.
Old Today, 11:46 AM
tepelena's Avatar
Man, the GL Class (X164) can be really frustrating with its quirks. The hesitation you're feeling between 15-20 mph could be stemming from a few different areas. It might be an issue with the throttle body or the throttle position sensor, causing inconsistent acceleration signals. Another possibility is a problem with the mass airflow sensor, which can disrupt the air-fuel mixture and lead to hesitation under light load. Additionally, the transmission control module might be struggling with shifting smoothly at those specific speeds, or there could be a minor fuel injector clog that's only noticeable during gentle acceleration. Wiring issues or faulty ground connections in the engine bay can also intermittently affect performance, leading to the symptoms you're describing. You should probably run a full system scan. There should be fault codes on at least one or more control modules related to this. If you want to figure this out yourself, then you will need to get a full system scanner. the "youcanic full system scanner" is very good at diagnosing all systems, and there are other scan tools that can do this. Just be careful to use a full system scanner or you may scan the car and see no fault codes, as some scanners cannot read all vehicle systems.
Old Today, 01:12 PM
Elbeau's Avatar
Mercedes gl450
Can the Youcanic do any programming, or is it just a scanner?
Old Today, 01:49 PM
DennisG01's Avatar
'08 GL 320 CDI
I think he's a robot. Seems most of his (it's?) posts are about recommending that scanner - I asked him for clarification a week or so ago, but there's been no response.
Old Today, 01:55 PM
Elbeau's Avatar
Mercedes gl450
Okay. Thanks for that info. Seems like a rather wordy response for a bot, though.
I often fail to get responses on follow-ups to posts.
Old Today, 02:46 PM
DennisG01's Avatar
'08 GL 320 CDI
I agree - but that AI crap is getting ridiculously smart. Or, maybe he sells that scanner?
I'm withholding judgement (sort of) - but I'm curious
But the response always seems thoughtful - I'll give 'em that!
Old Today, 02:49 PM
DennisG01's Avatar
'08 GL 320 CDI
Rabad, running fuel injector cleaner certainly wouldn't hurt anything.
Does the hesitation time with a gear shift? Pay attention to the revs... or try manually shifting to see if it follows.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Quick Reply: Acceleration hesitates at 15-20 mph
