Dash Cam
Old Feb 25, 2025 | 04:49 PM
CA400's Avatar
C400
Dash Cam
Hi guys,
I bought a USB to try out the integrated dash came on my GLC63. Does it start automatically? Currently, every time I start my car, I go to the APPS options and turn on the Dashcam.
what is your guy's experience with this feature?
Thanks,
Old Feb 25, 2025 | 05:45 PM
aviator787's Avatar
2024 GLC43
It starts automatically ... I have it also and works flawlessly
Old Feb 25, 2025 | 05:46 PM
aviator787's Avatar
2024 GLC43
Originally Posted by CA400
Hi guys,
Thanks,
What year is your 63 ? Do send pics
Old Feb 26, 2025 | 07:31 AM
KrayzieVetteGLC's Avatar
'25 GLC 63, '23 GLS600, '24 z06, '25 Maverick, '24 Wrangler
Mine starts automatically. I have a ‘25
i think there was an option to check for this.
Old Feb 26, 2025 | 08:11 AM
W205C43PFL's Avatar
Might be something along the lines of loop recording.
Old Feb 26, 2025 | 08:38 AM
aviator787's Avatar
2024 GLC43
Yes that's the option
Old Feb 26, 2025 | 09:07 AM
Old Feb 26, 2025 | 10:42 AM
W205C43PFL's Avatar
Awesome! Thanks for confirming and thanks for the pictures.
Old Feb 26, 2025 | 10:44 AM
W205C43PFL's Avatar
Just keep in mind you do need a good sd card/storage device like samsung endurance sd cards that are specifically designed for constant rear and write/overwrite like for dashcam. I also remembered from other threads that you need to have a specific file format and was it that the storage capacity matters as well?
Old Feb 26, 2025 | 10:56 AM
Amazon Amazon
thats what im using. Been working fine so far. ::Fingers crossed::
Old Feb 26, 2025 | 11:13 AM
W205C43PFL's Avatar
https://www.amazon.com/gp/aw/d/B0D92...b_b_asin_title
That is not rated for dashcam use I don't think but if it works, it works : )
Old Feb 26, 2025 | 11:15 AM
Yea I got it for $50 during black friday, had it lying around. Plugged it in no formatting or anything required, and no errors so far.
Old Feb 26, 2025 | 11:16 AM
W205C43PFL's Avatar
Old Feb 26, 2025 | 11:17 AM
W205C43PFL's Avatar
The benefit of higher storage say for example your 500GB vs 64GB is that it doesn't have to overwrite the cells as many times as it never gets the chance to be filled in full once (especially depending on how much you drive). Which means it will last longer even if it isn't dashcam rated.
Old Feb 26, 2025 | 11:18 AM
W205C43PFL's Avatar
Too bad there is no parking mode? I don't think? Which traditional dashcam has but then you need to hardwire those to have parking mode anways, the OEM setup is a good compromise although you don't have sound?
Old Feb 26, 2025 | 11:21 AM
W205C43PFL's Avatar
That got me curious, in the previous gen Mercedes, there is a built-in hard drive that allows you to store media, say from a cd. Good days I guess. Don't new MBs still have a hard drive to store something, why does MB force you to buy your own storage media to store dashcam files? Or maybe I am answering my own question, the storage capacity built-in is tiny?
Old Feb 26, 2025 | 12:41 PM
CA400's Avatar
C400
Thanks for the replies guys.
I have a 2021 GLC63, so not sure if this year turns on the dash automatically? I bought a SANDISK 512GB ULTRA DUAL DRIVE Mini-C USB form BestBuy at a cost of $56. I plug it in the center console then moved it to the front charger to see if that started it automatically. When I start it manually I see a red dot on the MBUX screen however if I don't the red dot is not on. I'll play more with the settings later in the afternoon.
Here are some pictures for those who asked.
was able to drive onto the beach in Eureka.
Old Feb 26, 2025 | 05:12 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I bit the bullet, and paid the $200.00 to have the dash cam feature activated. I bought 2 thumb drives and a connector wire to reduce the chance of damaging the USB port. One of the flash drives has a lightning connector, so I can download footage to my elderly iPhone.
I formatted the drives before plugging them in.
I am not fully satisfied with the MB dash am feature. I assumed(bad move) that since there were so many sensors and cameras on the car, it would be like the Tesla, and allow recorded footage to be viewed from all of them.
But unless there is some setting that I am missing, I can only access the video from the front camera.
I am considering adding an off the shelf dash cam to record side and rear views.
Old Feb 26, 2025 | 06:44 PM
W205C43PFL's Avatar
Originally Posted by MB2timer
I bit the bullet, and paid the $200.00 to have the dash am feature activated. I bought 2 thumb drives and a connector wire to reduce the chance of damaging the USB port. One of the flash drives has a lightning connector, so I can download footage to my elderly iPhone.
Sadly it uses the AR camera only, the other cameras, only available in the Guard 360 feature but it only records if there is a damage detected and you have to manually enable that feature.
Old Feb 27, 2025 | 04:41 PM
Jayhawk79424's Avatar
2024 GLE 53 AMG;2021 GLS-580
Are you using the MB Dash Cam, that is installed on newer MB's? I know you have to pay the one-time $200.00 and My Mercedes will operate the camera, as I understand.
What storage device are you using? SD Card or USB drive? Are they available from local MB Parts Dept or suggestions? Also, any other advice or tips? How are the USB, into the USB Port for Android Auto, or? The SD Card??
Thanking you in advance,
Bruce
Old Feb 27, 2025 | 05:04 PM
Bruce
you wrote all that and all your answers are literally in the thread already, with clickable links lol. Ps i don't know if this is for everyone but the dashcam is $160 in my app right now a week after i paid the $200, of course)
Old Feb 27, 2025 | 06:10 PM
CA400's Avatar
C400
Updated: I went back to the dashcam app and went deeper into the setting, it now starts at startup VERY simple.
Thanks for the input guys!!
I was going to ask about the other cameras being used at the same time as the dashcam but MB2timer and W205C43PFL already answered that question. I did notice that when a car got near me the rear camera was activated, do these events get recorded?
Old Feb 27, 2025 | 06:56 PM
W205C43PFL's Avatar
nope, only if there was a collision but you need to manually enable it, it is called Guard 360.
Old Feb 27, 2025 | 06:58 PM
W205C43PFL's Avatar
https://mbworld.org/forums/eqs/83882...ages-asap.html
Old Apr 17, 2025 | 07:51 AM
DESAL's Avatar
GLC SUV 350e Verde Silver Metallic
FYI
In my 2023 GLC300 SUV the dashcam is keyed to the profile. Daughter in a slight fender bender and when I went to see the video it didn’t exist because it wasn’t turn on in her profile. I have it on in my profile but always thought once it was on it was on across the board. Not so, I turned it on in the guest too. So if you have more than one profile suggest you check all profiles.
