GLE V167 300d make 2019 turn signal indicator faults
Old Mar 2, 2026 | 05:58 AM
andycqp's Avatar
I have had front right indicator fail on and off, before failing completely, followed by front left indicator fail.. in a span of 3-4 weeks
Both front indicators show error and do not turn amber
All other lights work, including multibeam
Old Mar 2, 2026 | 12:49 PM
notlimahrelyt's Avatar
2014 C300 Sport / 2022 GLE 450
Any condensation in the housings?
Old Mar 2, 2026 | 02:32 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Not under warranty I assume. Maybe check the connectors under the hood. Seems odd both would go out unless it's a common power lead plug or ground.
Old Mar 4, 2026 | 04:32 AM
andycqp's Avatar
hi, no condensation. Headlights are intact. Suspecting SAM or Ecu related. Not sure how both can stop working around the same time
Old Mar 4, 2026 | 04:33 AM
andycqp's Avatar
5 year old car. Connectors under hood are all ok. It is indeed very odd. Suspecting electrical ECU / SAM related but no clear pathway to walk yet
Old May 5, 2026 | 02:18 AM
mbnorthcentral's Avatar
Same fault
Any news on what you have found. Mine is the same although rh only.
Old May 6, 2026 | 02:42 PM
andycqp's Avatar
no, i eventually had to replace both lights
Old May 6, 2026 | 02:44 PM
andycqp's Avatar
after 6 weeks, couple of mechanics with lots of diagnostics, i ended up replacing the whole light, both sides lh & rh
luckily got a crazy deal on ebay for a new light from US
Old Today | 10:24 PM
RobertoCarlosMB's Avatar
GLE300d and A350
Hi andycqp. I am experiencing this problem right now. Before i move on to 2nd mechanic, where did you source the light from? I might be saving myself time money and anguish doing what you did early. Early quotes suggest $10K+ to fix. That is a lot of money :-(
Surely this issue is worth raising with MB. From my POV this is a design and reliability issue they should be aware of.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
