Please Help Me with my 2011 C300
Old Apr 24, 2026 | 09:33 PM
SlimWitDaBenz's Avatar
C300 4matic
I was driving my 2011 c300 4matic on the interstate earlier today when I lost acceleration. I turned the car off afterwards & tried to start it but it was like the engine wouldn’t turn over. A few hours later neither of my two keys would start the car or even get the lights on the dash to light up. There’s no clicking when the key is put into the ignition I just get a message that says “remove key from ignition.” I’ve replaced the battery & I feel like it may be an EIS as far as the car not starting but I don’t believe that would’ve made the car lose throttlw while driving. Can anybody please give me some type of insight?
Old Apr 24, 2026 | 11:05 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Do you have s scanner (not an inexpensive code reader)? The first place to start would be to scan for trouble codes that could point to the failure.
1-No unlock sound + the Remove Key message points to an ESL failure. But that doesn’t usually lead to loss of power while driving.
2-A rather remote possibility that could cause all the symptoms would be a fuse in the prefuse block blowing and cutting power to the front SAM. But those fuses are large and won’t blow without a catastrophic short in the electrical system.
That’s why s scanner with a dedicated Mercedes scanner is the place to begin.
Old Apr 25, 2026 | 01:51 PM
TimC300's Avatar
With a multimeter what is the voltage at the battery terminals? Should be 12+ volts.
When you put the key in the ignition can you turn it?
Old Apr 26, 2026 | 10:14 AM
C300 4matic
Sorry for responding late
the battery is 12+ volts for the terminals & the key can turn when I put it in the ignition, just nothing happens when I turn it
Old Today | 10:02 AM
gav24v's Avatar
W204 C250 Sport (AMG Package with Pano Roof)
In the absence of further diagnostic codes the no crank, no ignition lights and remove key message points to a failed electronic steering lock. Can you still turn the steering wheel? If so disconnect the battery and remove the ESL. You do not want the ESL to lock at this point as it makes removal a difficult task. I recommend you replace the ESL with an emulator for even though failure is likely not connected with the engine cutting out, it is the probable root cause of why you cannot start the car.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Magnificent New Mercedes-Maybach S-Class Revealed: 12 Things to Know
Slideshow: Mercedes-Maybach has refreshed the S-Class with new lighting signatures, AI-driven software, and even more elaborate rear-seat luxury.
By Verdad Gallardo | 2026-03-25 18:01:51
