Another Airmatic thread---but with a twist
Jump to a week or so ago, when the front two springs deflated inexplicably. Trouble shot with my scanner (not bi-directional or as good as I would like) and was misled to believe that it was a failed ride height sensor. Replaced both of the front ones and still get an error: Line Leak. So after further troubleshooting, I find that I never hear the compressor running. If I come out first thing in the morning, and start and try to raise the vehicle, the light will flash for a while, and then I get the "Malfunction" message on the dash. But no indication the compressor is active. I have tried swapping out the compressor with an old one, and no difference. I've checked/replaced the fuse and the relay, and nothing. Checked everywhere for leaks, but found nothing.
The most confusing part of the current situation is that it appears that the system is not sending power to the compressor at all, as if it is in a "protective" mode, yet, when I scan after clearing the line leak code, nothing new comes up. My scanner doesn't show any pressures, just the various codes, and the feedback from the ride height sensors.
Thanks in advance!
Have you verified that the front air springs are not leaking? When replacing mine recently, we found that over-torquing the compression nut on the air line can squeeze the o-ring out of position. Check for leaks using soapy water.
Regarding the "leaky line" error: This could be due to a malfunctioning compressor relay. The system apparently does not sense whether the compressor is actually running; it only knows that voltage is being applied to the relay, not that the relay is applying voltage to the compressor or that the compressor is running. (At least, this is my understanding. Don't quote me.) Try replacing the relay; it's a cheap diagnostic.
The relays are also dangerous. There is a diode inside them that shunts excess voltage, created when the pump motor is turned off, to ground. If the diode shorts out internally, it will route excess current through the fuse block circuit board traces. Failure here would cause all sorts of additional problems, so seems unlikely in your situation, but it couldn't hurt to lift the engine compartment fuse-and-relay board and look at the traces underneath.
Also, please tell the manufacturers of your various replaced components. Some low-budget valve blocks simply don't work at all. Cheap compressors can fail very quickly.
- Replaced the relay, and checked the front and rear fuses
- replaced the valve block
- swapped out the current compressor with an old "worn out" one, just to test and see if it runs...no change.
Do the basic diagnostics rather than trying to divine what is going on via your scan tool. I beat my head against the wall for weeks because I couldn't understand the diagnostic information, and couldn't believe that a new Arnott pump would fail after 20k miles. So do the soapy water test on everything you disturbed while replacing, and consider whether you might have installed new but low quality parts. There's no shame in that; we've all refused to believe that new parts could be bad. In large part due to Chinesium ingredients (Arnott pump Made in China), "Nothing works anymore." We've got guys, myself included, that installed brand new, supposedly high quality, CV axles that are going clink clank clunk. It's maddening.
it doesn’t and that’s normal.
confess I’ve never jacked up a wheel with the ignition on.
All is not well yet, though. Now when I start the car up, the compressor hums for a while then eventually stops. I then get the "Malfunction" error, and when I read the codes, it now has only the "Suspension Strut is implausible". It still doesn't rise, so either my old worn compressor isn't putting out enough air, or there is still a massive leak. Still scratching my head. I figure a new compressor is the next step.
https://rebuildmastertech.com/merced...-ads-airmatic/
You need to clear the error codes before the suspension will resume normal operation. It will helpfully avoid running the compressor when it thinks the system is leaking. The codes might self-clear with drive cycles, but it is much quicker and safer to do it manually.
If you have the means and inclination, a bidirectional scan tool is highly recommended. For example, accessing the Airmatic module, you'd be able to raise and lower individual corners on the vehicle. This might have saved you some pain.
My general impression that Autel is on the leading edge of third party scan tools - my MP808 seems quite solid - but there may be others.
No-name parts are hit-or-miss. I installed a valve block that was non functional out of the box. TPMS lasted from one to five years. But my no-name thermostat has held up faithfully for 50k miles now. To be safe, I now only install the best, near-OEM, parts - but still that is not a guarantee I won't be found crying in the garage.
Bilstein and AMK remain solid thus far, but I do not know a reputable manufacturer for the valve blocks. Fortunately if you don't run the compressor on a leaky system, moisture won't get in and the valve block will last a very long time.
P.P.S. Replace the compressor intake air hose when you replace the compressor. The molded rubber has a tendency to crack and thus let in dirty air, presumably leading to premature wear.
Anyway, when I saw that none of the air lines had actually engaged their retaining rings in the valve block, it is no surprise that the system was leaking. I can understand a compressor losing its compression due to wearing out, but am surprised that motor failed on this compressor. Tried bench testing it, and it is dead for sure.
