C63 AMG (W204) 2008 - 2015
C63 foot brake/parking brake
Old May 29, 2026 | 01:57 AM
Madcow554's Avatar
2012 C63 P31 and 2011 E550 Luxury
Hey guys my foot brake/parking brake keeps getting stuck and wont release or spring back when i pull the hand catch, i already replaced the whole assembly with a new one about 3 years back and already it's stuck to the floor again and barely releasing. Is there an aftermarket kit or fix for this to make it stronger? i dont get why my E550 has never had this problem but my C63 is plauged by it. Indy wants $550 to replace the assembly.
Old May 29, 2026 | 09:28 AM
OBP's Avatar
OBP
E63 S AMG, CLS550 4matic, C63 Ed 507, Volvo XC90 T8s
Hah ! I am in the same boat as you except my other MB where the parking brake releases just fine is my 2014 CLS550. And the C63's parking brake is indeed sticky. I believe many of the C class platforms from this era have this issue - my 2015 GLK that has been sold had the same problem. It is a design flaw I expect and we will have to live with it. Don't bother replacing with another new part - the same issue will arise in time. I know - I had the part replaced on my GLK in the past and nothing was resolved. I use my left foot and encourage the parking brake to release ( push upwards with your toe hooked underneath) while simultaneously pulling on the release catch. Great job Mercedes, great design right here !
Old Yesterday | 10:54 PM
Gazam's Avatar
Common issue on W204 C63. The return spring inside the pedal assembly is too weak. New assembly will fail again. Don’t bother with aftermarket none worth it. Best fix: lube the cable and mechanism with white lithium grease, then manually help the pedal return with your foot every time. Or pay the indy once and hope it lasts. Annoying but common. E550 has different design.
Old Today | 01:34 AM
roadtalontsi's Avatar
10 C six trizzle
parts wear out on a 15year old car. "design flaw" is an interesting way to put it. Replace it and it will fail in another 15 years. lol. I guess my tires are a design ffaw too they only last 3000 miles on the rear.
Old Today | 02:15 AM
Madcow554's Avatar
If you go back an read my post, i stated that i already replaced the part once 3 years ago and under 10,000 miles of use. I have had multiple Mercedes and none of them had this issue. If it lasted 15 years i would be fine with that.
Old Today | 11:38 AM
AMGSPY's Avatar
2014 C63 507 Coupe
Yeah, mine did that and was replaced under warranty. The new one comes up off the floor, but just barely. A bad design with a wimpy return spring.
Old Today | 12:45 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
anyone have a diagram of the spring so I can find a slightly stronger one to replace mine with? I'm thinking a stronger spring and some white lithium grease should do it.
Old Today | 04:54 PM
10 C six trizzle
going on my original with no issues 73k mi and owned it since 2012 10k mi. use my parking brake basically every time its parked. Are your parking shoes adjusted properly?
Old Today | 04:55 PM
Madcow554's Avatar
how do i check and adjust it?
Old Today | 05:48 PM
TimC300's Avatar
Here is a good post on the parking brake pedal function: https://mbworld.org/forums/c-class-w...lubricate.html
Is the release not working? I cant imagine the springs that reset the parking brake pedal wearing out.
I always thought the springs on the rear parking brake cables are responsible for resetting the parking brake pedal. I had to replace the drivers rear parking brake cable and it was pretty difficult with how strong those springs are. At the time I dont think I was installing it right since I didnt have access to the MB manuals, I just winged it. My rear dust shields were so rusted that the springs holding the pads in place had fallen off while driving. Very dangerous situation. The spreader was so rusted I couldnt open it up to remove the parking brake cable, cut the cable instead.
Then the springs in the parking brake pedal area are responsible for returning the pads in away from the rotors.
