Controversial topic- do transmission service or DON'T F'KING TOUCH IT
We all know a guy who knows a guy who recommends against this. I ignore those guys and always get my transmissions serviced at the recommended intervals.
Legacy ATF relied on viscosity that lasted substantially longer.
If you want guaranteed failure, ignore minimal maintenance.
100% of the friction material not deposited in the valve body keeps circulating.
Steel plate material gets caught by magnets
The last days may go like this...
As the old ATF gets heated, suitable viscosity is incresingly lower to the point TCU can no longer compensate for lack of pressure with PWM valves.
Slippery clutch packs shade mor contaminants under stress.
Steel plates start warping from accumulated heat
Enough contaminants plug solenoid valve screens and magnetic shaft Rpm sensors go blind.
TCU quits with fault codes...
Complete rebuild needed, not just dirty conductor kit.
Our best bet is to keep fresh ATF in the working range. Learn to read good shifts vs. bad shifts to limit abuse.
Premium deeper aluminum tranny pans are available with cooling fins and more easy drain (~$900!)
Shorter drain intervals help limit contaminant level.
https://youtu.be/3TtYJuJDbks?si=8oE8T94YxSV9C6CD
Is the transfer case separate on the 463 even with the 722.904 transmission?
I replaced the fluid and filter in my 2010 W204 last year at 160,000 miles. The old fluid looked pretty good and when I cut open the old filter I did not see any metal bits which was a relief. The magnets had some black stuff on them, im assuming it was really fine metal. I was glad to clean it all out. The car runs and drives great. The Carfax showed the transmission was serviced at 40,000 and 80,000 miles at a Mercedes service center but then there were no more records of it. Though when I did it I noticed a generic non-Genuine MB filter so im assuming the used car dealer I bought it from did it.
Mine uses the red fluid.
He is not blowing air into any valve, but rather through the valve body and transmission, to remove fluid from the TC and cooler without disconnecting lines or fiddling with the TC drain plug, which can be tricky.
