SL/R129: New Battery: Window & Hardtop issue
Ive replaced the battery with a new one and am now having issues with the windows and hardtop.
The windows are not dropping as i open the doors, and are moving to far up into a position too high for the roof, above the rubbers.
Also i am unable to eject the hardtop.
Its almost like the car thinks it has the softtop on, not the hardtop.
Any help or ideas are appreciated.....
That single action resets the window timing.
I agree that you need to reset the windows, but I don't think the process is quite as was described. You should put both windows down a ways; but then, one at a time, raise each UP and after it hits the rubber at the top and stops moving, continue to hold the button UP for two seconds.
It sounds like you are pushing the top control button the wrong way. As the other guy said, read the manual and check that you're doing it right.
