SL/R129: Please Some One Help Meeeee My Sl320
Hello If Someone Can Help Me, I Got A 1996 Sl320 That Has 110000 Miles On It The Car Runs Great No Probs But Last Time I Changed My Brakes I Feel Like There Is This Vibration Under The The Gas Padle This Is So Annoyiong Now The Car Pulls To The Left And Right All The Time I Balanced Me Tires Its Like Every Bump I Hit I Feel It Now I Have Low Pro Tire And Amg Wheels And When I Bought The Car I Didnt Feel This Under My Legs And For The Car Pulling To The Left And Right I Cant Leave Me Hands Of The Wheel It Will Pull How It Pleases Now If I Hit The Brake And Let Go Of The Wheel Its My Luck If The Car Wants To Go Left Or Right And This Noise That Comes For The Floor Under My Feet Its So Annoying Its Like A Grinding Noise And When I Hit The Brake Or Slow Down Its Like I Feel It Even More Under My Feet, Even When I Go On The Highway When I Hit 80-100 Miles Its Shacking I Really Dont Even Know Where To Start Mercedes Dealer Said To Me Its Normal I Was In Shock So Please If Anyone Can Help Me Thank You For Your Time.
One of two things would be my best guess. Either the tire pressure is low (check inside panel of fuel door for proper settings) or the tires were not balanced with metric weights (make sure MB dealer balanced them). These two problems are easily corrected so no worries. However, lets hope its not a chassis related problem, which can be very costly. Hope this helps and good luck.
Regards
Regards
hey thanks well the tire pressure is all good the tires are well balenced i mean i didnt take it to mb dealer i took it my discount tire they balanced them out for me i really dont know what it is but could it be the agliminet you know please get back to me thank you
I did the same thing with my '02 S500. I bought the tires from a auto garage and had them install and balance the tires (it seemed simpler and more convenient). Turns out, above 80, there was a vibration and the car drifted to the sides. Had MB dealer replace weights with metric ones, and the car drove flawlessly after that, even to 100+.
I can't be sure it's not the alignment (since I never personally drove it), but I am sure that your descriptions were very similar to what was happening with my car (side to side at hwy speeds). The metric weights fixed it for me and I hope it works for you too. Buying the tires elsewhere is a good idea (ordered Eagle F1 GS-D3 online for my car), just make sure MB or any German Auto Garage balances them.
97 SL500
Sounds like you have a problem with one of your brake calipers, like one side is sticking or has more force during application then the other side. I'd check to be sure all the pads are correctly seated against the caliper and the correct pads where used in the correct locations on the car.
1999 Mercedes Benz SL500 & 2009 E350 4Matic Wagon
Help with SL320
This is a long shot, but on the ML site I read where problems occured when rims were replaced and the lug bolts were now too long. Could this be your problem and the bolts are rubbing on something especially under hevy loads that are present when breaking or at high speeds as the wind load forces the car closer to the road? Good luck!
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
