SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1990 500SL stalls, gauges wacky
Old Apr 21, 2006 | 10:41 PM
Stirling500's Avatar
R129, W124
Hey folks, I'm hoping someone might have some insight into this, no comments on this post over at Mercedesshop:
If I start my 1990 500 SL after it has been disconnected from the battery for awhile, both the engine and the instrument cluster are fine (ECU has been reset??). However after shutting down long enough to gas up, and restarting, the engine stumbles and stalls and the gauges go wacky. The tach will show slower than the engine is running, the fuel economy gauge bounces back and forth like a pinball machine, and the other gauges may or may not work at all.
If I do get the car moving (by not accelerating too hard) the speedo underreports my speed by about two-thirds. And the car will surely stall again at the first light. Once up to speed though, its fairly smooth.
Disconnecting the battery for awhile starts the process over again.
Help!!
Old Apr 22, 2006 | 01:47 AM
Pigzmickey's Avatar
1998 SL 600 ///AMG. 1997 SL 320. 1999 SLK 230K. 2001 BMW R850.
Test the battery, use a proper battery tester not multimeter.
Old Apr 22, 2006 | 08:53 AM
R129, W124
Thanks. Did the test and its good.
Actually its a pretty new Mercedes battery.
Old Apr 23, 2006 | 06:05 PM
R129, W124
Any other ideas? It does seem like the engine is getting too much fuel - at least the fuel gauge seems to indicate that.
We disconnected the cold start sensor and that did work for awhile - connected it would stumble, disconnect and it would start up well and run well, but then when we shut down and restarted it would stumble again even though the sensor was still disconnected. Arggh.
Old Nov 15, 2006 | 05:17 PM
ataie's Avatar
2007 Mercedes SL550 Sport
jumping gauges
having the same problem on my 97 SL320. the battery light starts to flash, and the oil and other gauges start jumping around. the battery is new and it is charging close to 14. mechanic said these cars had a problem with grounding. any ideas???
Old Nov 15, 2006 | 05:37 PM
LeaUK's Avatar
'93 SL500
Do your Tell-tale lights extinguish intermittently when they shouldn't?
Bet's on your ignition switch...
It's well documented on several forums that SL ignition barrels are prone to failure. Had to replace mine a while back...all OK now
http://www.mercedesshop.com/shopforu...light=ignition
Old Nov 15, 2006 | 06:45 PM
R129, W124
Well after many months and lots of trial and error (including changing the ignition) we got to the bottom of the problem: bad ignition coil.
Put a new one in and it ran as smooth as a dream with no bouncing gauges.
Who'd a thunk it.
Give it a try and let us know if that fixes your problem.
Old Nov 16, 2006 | 02:36 AM
LeaUK's Avatar
'93 SL500
I'll bear that in mind Stirling, must be significant EMI to cause such bouncing gauges though.
Cheers
Lea
