SL/R129: turn-signal indicators and hardtop questions
Also, how do I remove the hardtop roof?
The hardtop comes off by operating the the top switch. It's been a while (years) since I've put the hardtop on my car but I think you pull back on the switch to pop the hard top latches (as if you are opening the softtop). No worries if you operate the switch incorrectly, just try the other direction if the top doesn't release and lift. Be sure to unplug the defroster wire at the back of the door jamb before you try to take it off. The top will release and raise up an inch or two then you just lift and carry it off.
