SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL500 95' Small Lighting problemo
Old Jul 22, 2006 | 02:18 AM
tonypro99's Avatar
As explaned in the title I have the reading lights working fine but for some reason when I have the switch click over so that the reading lights come on when the doors are open..the lights won't come on?
but If I toggle the switch to manually turn them on they will come on no problemo. Now this problem started when I changed one of the reading lamps since one of the clips broke on the old on so it would just drop out of the ceiling. Since then I have had this problem. Any Help is Appreciated. Thank-you.
Old Jul 23, 2006 | 04:40 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
If the lamps come on with neither door, then you likely have a problem with the light unit -- either a switch or the circuit board. But if the lamps come on with the passenger door but not the driver door, then you probably have a blown diode in the seat belt warning module.
