SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 129 SL Antenna...has anyone--
Old Sep 12, 2006 | 07:56 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
experienced a failure on a 97/98 SL with the combo MB cell and radio antenna? Mine works fine, but the mast is broken, and dealer tells me that there is no replacement mast available for that antenna. There is, of course, a complete antenna available that will fix the problem, but unfortunately it sells for about $600, uninstalled.
Question: has any replaced a mast on this type antenna and,
2: Is there any reason that these antennas cannot be replaced with the old style steel mast antennas? Since the MB phone functiion is useless, wouldn't it be OK? Makes sense to me, but hey, I'm not that smart.
Your input is appreciated.
Old Sep 13, 2006 | 04:10 AM
jjrodger's Avatar
I think I've posted elsewhere on this.
You can get the mast separately.
I can't see why you wouldn't be able to strip out the combo antenna and replace with a standard Hirschmann unit, but they are not cheap: $400+.
Old Sep 14, 2006 | 01:03 PM
mebeJOE's Avatar
SL500 2001 Formula 1 Edition;
You can get the atenna from a non-dealer for under $300 on the internet if you look around. I can't remember where I got a price quote from -- but I do remember getting a quote -- I decided to not replace it when I got Sirus -- I don't listen to regular radio anymore.
Ba-ba-b0oey. Ba-ba-booey.
Old Sep 27, 2006 | 11:46 AM
roverdish's Avatar
antenna mast
I found an OE mast on line for around $87.00. Aftermarket mast are much cheaper but may need some modification to work properly.
try here
http://mercedes-benz-parts-direct.com/epc-search.asp
there are also instructions on the site as to how to replace your mast.
good luck
Old Oct 1, 2006 | 10:11 PM
jtigr's Avatar
re antenna
I literally just had mine replaced this week, it was under 250 installed. i broke mine off a few months ago and have been putting it off.
R&H Mercedes in reisterstown, MD.
They could probably send you one to put on yourself.
I beleive the antenna is around $150 or so. THis is the whole kit.
email me at jfruhling@nextel.blackberry.net if you want more info.
Old Oct 2, 2006 | 07:55 AM
allenjdmb's Avatar
Yes, OE mast is available...it's
140-827-0001. About $80 ish. Works just right.
