SL/R129: 95 E320 Cabriolet hydraulic top operation problem
What's the magic that needs to be done to get the top to work properly after repair? What needs to be reset? I remember having a similar problem that last time I worked on the hydraulics. It seemed to work itself out after a while. I've tried everything I can think of... manually setting the top in the full up and full down position, then starting operation... disconnecting the battery in hopes of resetting the mechanism.... all to no avail.
I'm posting on the SL forum because there's a lot of similarity between the mechanisms and there's so few people in the E-Class forum that know about cabriolets.
Code 10 - Soft top fabric bow "raised" limit switch
What my top does, is from the top-up position, it unlatches and raises the compartment cover, raises the rear glass, then faults.
I took the three-in-one limit switch unit out from the driver's side rear quarter and tested them. All switches work fine. There's no adjustment, and I can feel the switch click when I raise the rear glass manually to the up position.
Am I checking the proper switch?
