Hi everyone,
I just bought a 99 sl500 and FJones recommended the following: (I'd like input on these issues as I'm not really savvy about this area) Is there a good indy service group in OC near Irvine. I feel like I'm getting ripped a bit.
Main pan leaking 845
Both front upper strut mount bushing torn 570
Both tie rod ends 295
Steering shock worn 112
Trans 13 pole connector and conductor plated updated 810
Belt tensioner 364
front timing cover oil cap 110
Grand total dealer = 3106 Ouch. Is this legit pricing? Are these major issues?
Thanks,
Larry
Belt tensioner 364
Thanks,
Larry
PM me, I'll inrtoduce you to someone at FJ that might be able to cut you a break.
Those prices seem normal for FJ, can't tell what they're doing exactly but ...
There are a few MB/BMW shops on Bristol you could try
Belt tensioner 364
Thanks,
Larry
How many miles do you have on the car??...... Your car is an 99..... I don't think you need all those...... My car is older then your and I don't need all those.... I think you been taking for a ride........Originally Posted by larryrt
Hi everyone,I just bought a 99 sl500 and FJones recommended the following: (I'd like input on these issues as I'm not really savvy about this area) Is there a good indy service group in OC near Irvine. I feel like I'm getting ripped a bit.
Belt tensioner 364
Thanks,
Larry
Fletch has a good thing going but he sits on some pricey real estate in Newport Beach. All of those items look fairly common for a 8 year old SL. I doubt all of them need to be done at once.
For instance, is oil dripping or are the seals just wet? Belt Tensioner is important to do proactively, steering stuff will bring it back to feeling new again, cracked strut bushings are very common and should be replaced before they are really bad. Yawn...I don't see any emergency issues, but if you want peace of mind all of those should be done sometime soon.
I haven't lived in SoCal for years, back in the day I took my 450 to Dales Mercedes on the border of Newport and Costa Mesa. He knew his Benz's and was always a voice of reason. Not sure if he is still around but guessing you could get the job done for 30-40% less.
Bagger
Bagger
Larry,
I'm sorry that you have been given this kind of news on your 65K miles car. Did you have this car checked out prior to purchase?
I only use M-B Stealerships for information gathering. Otherwise I have had most of my work performed by INDY's. I have several local INDY's that I use.
I believe this guy is trustworthy.
Michael ****
M.B. Stars
788 Francesca Dr. #1a
Walnut, CA 91789
626-913-0780
You can also contact the following OC INDYS.
Haus of Mercedes, 714-957-8281 Joe
OC Benz, 714-556-2369 Jeff
Tony's German Auto Care, 714-850-0375 Tony
Michael ****
M.B. Stars
Walnut, CA 91789
626-913-0780
Currently Active Users (1)
