SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: car vibrating
Old Nov 16, 2007 | 10:56 PM
TripleBlack's Avatar
1995 SL 500
car vibrating
As I was driving this evening, I stopped for a light and the car started vibrating. The rpm's are only at 5. When I speed up it gets better but is not good. The car shaks. What is wrong?
It is a 95 with 36,400 miles
Old Nov 16, 2007 | 11:19 PM
gqmagic's Avatar
96 SL500, 97 E420
Sounds like engine knock, when was the last time you had it on the freeway and blew it out?
Old Nov 17, 2007 | 07:37 PM
Just Some Guy's Avatar
1997 SL500, 1994 Impala SS on steroids, 2007 MV Agusta Brutale 910R
An engine knock is usualy caused by a failed bearing in the rotating assembly somewhere, and is a sign of impending doom....really bad.
The trouble you are experincing can be any number of things, a bad coil pack, bad gasoline, the throttle body could be on its way out, or even a bad motor mount. This is not going to be something you can diagnose on a forum, there are many things that could cause the car to idle poorly.
Old Nov 17, 2007 | 11:05 PM
Bigdot's Avatar
some
u most likely have the stock spark plugs since you have such low miles. change them out, get OEM BOSCH not the platnum ones.
Mark
Old Nov 17, 2007 | 11:19 PM
gqmagic's Avatar
96 SL500, 97 E420
At 36000 miles it shouldn't be to serious, the proper octane gas 91+ and a good long drive may be whats needed. Or to the mechanic.
Old Nov 18, 2007 | 02:03 AM
AMGSport's Avatar
An earlier post recommended that this is difficult to diagnose on a forum, and I agree. I will say I had a similar experience that turned out to be a loose vaccuum line...and the car did not throw any codes...good luck!
Old Nov 22, 2007 | 12:12 AM
1995 SL 500
It was a bad rotor and distributator cap
