SL/R129: Headlight wiper adjustment
2003 SL500
One of my headlight wipers does not park as low as the other. Is there an adjustment somewhere?
Rocco 99 SL500
Rocco 99 SL500
i just had to remove mine when i retrofitted projectors, and i think the design is probably similar to yours.
if you look at this pic, the rear of the arm (where it connects to the car) flips up, and you'll see a nut. if you undo the nut, you can pull straight out, and the arm should come off. the little bolt it's mounted on has grooves in it, so you can put it back on at the angle you want..
