SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Small black button on rt side of steering wheel stalk.
Old Apr 13, 2008 | 10:41 AM
Rocco Vespe's Avatar
2003 SL500
Does anyone know what the small black tube with a cap at the right side of the base of the steering wheel stalk is for? Is it for testing something??
Rocco
99 sl500
88 xjs convertible
82 xjs coupe
2001 xj8
Old Apr 13, 2008 | 11:45 AM
rcltrh's Avatar
1996 - C220/2001 - ML430/ 2005 RX-330
Rocco
99 sl500
88 xjs convertible
82 xjs coupe
2001 xj8
Picture? If you have NAV there is a push to talk stalk button. You push the button then speak a command to the NAV system. However not seeing what you're talking about I'm not sure. What year model?
Old Apr 14, 2008 | 11:14 PM
pcviewer's Avatar
2006 Aston Martin Vantage
Bottom right? I see nothing.
Bottom left? The small switch? It adjusts the steering wheel.
Top right? Something to do with the integrated phone, if the car came equipped with one.
Basically, all I see around the base are:
Cruise control stalk
Signal/High beam stalk
Phone stalk
Steering wheel adjustment switch
As mentioned, a picture would be very helpful in determine what you are talking about.
Old Apr 16, 2008 | 07:26 AM
2003 SL500
small black button
Its on the top right and its about 3/8 inch diameter
Rocco
Old Apr 17, 2008 | 07:34 AM
CWW's Avatar
CWW
SL600
It's for voice command.
Pull the stalk and hold it for about 2 seconds and then say "Radio Station 104.5" or "Call 904-123-4567" and this woman's voice will come on and say "Ok, dialing the phone" or "radio station has been changed to 104.5". Well, assuming you have done the upgrades and still have a phone or bluetooth.
It does a bunch of other stuff as well, I think you may be able to adjust the air conditioning with it. Look, you should have a 300 page manual for this thing floating around along with the rest of the books for the car. Just read it, it will answer your questions.
Old Apr 20, 2008 | 05:13 PM
pcviewer's Avatar
That is interesting. I never knew that. I just went by the image on the stalk itself. However, after reading your post, I decided to skim through the manual myself. Unfortunately, the information on its usage is non existent in the 300 page manual (again, I was just skimming). There is a "quick reference" booklet, but the information on the voice stalk is very sparse, mentioning to reference another manual that I do not have.
I have been searching on how to use it and I believe I read some of your contributions on another forum but I have a question I do not think was addressed in the forum I was reading...
Is a phone required to use the voice activation? My car does not have a phone installed (push the phone button on the radio => "NO PHONE" message). I have tried using the stalk and even holding the phone button for a couple seconds but either attempt results in nothing. Thanks.
Old Apr 21, 2008 | 04:06 AM
luda's Avatar
ML 320, 1998
This is the manual:
http://phdwebsite.powerpulse.cc/VCM/...M%20Manual.pdf
and:
http://home.earthlink.net/~phdwebsite/vcm.htm
also some interesting reading here:
http://home.earthlink.net/~phdwebsit...phone_info.htm
Hope this help, Per.
Old Apr 23, 2008 | 10:08 PM
pcviewer's Avatar
Originally Posted by luda
Thanks for the links. I have been following the manual but it still doesn't work. I guess after a couple days of testing without positive result means my stalk might be broken (I still get the tone that the system is active when I start the car). All I wanted to do was test out the feature. I don't use the radio much and could care less about the phone function. Thanks for the help though.
