SL/R129: Can I switch seat bottoms? 1999 sl 500
Thanks,
Rocco
1999 sl 500
1988 xjs convert
1982 xjs coupe
2001 xj8
Thanks,
Rocco
1999 sl 500
1988 xjs convert
1982 xjs coupe
2001 xj8
If you have small children sitting in the passenger seat, you should probably leave it alone.
It is possible that detaching this sensor permanently will throw an error code. I don't know for sure though. In fact, I don't know at all. I don't know if you want to start your car while the sensor is detached to test it out (I wouldn't. I would wait for someone with useful knowledge to chime in).
Some info from MBUSA that may relate to the wire you found:
Occupancy sensor prevents the passenger's front and side-impact air bags from deploying if seat is unoccupied. ETRs will not deploy if seat belt is unfastened.
