SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Hard Top/Soft Top Problem
Old Jul 12, 2008 | 12:39 AM
2mbusa's Avatar
1999 Mercedes Benz SL500 & 2009 E350 4Matic Wagon
At times, mostly after raising or lowering the soft top or changing tops, the red warning light in the top control switch plus the gong activate. This can happen while driving for no reason at all. I would assume there is a micro switch somewhere that is out of adjustment as when this happens the tops are always securely fastened in their locked position. Usually I can make the alarm go away by moving the switch fore and aft a couple of times thereby locking and unlocking the tops. Any suggestions ??
Old Jul 14, 2008 | 08:53 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Check the limit switches for the latches as explained here: http://www.benzworld.org/forums/r129...inks-roof.html
Old Aug 20, 2008 | 11:25 PM
2mbusa's Avatar
Guess I am a slow learner, as I could not find the info I needed on the above web site. Any other help would be appreciated -- thanks
