SL/R129: winter storage
You can't get away with a front-end-heavy rear wheel drive car up there, at least not one that also sits 3" off the ground. Cars like this have to be stored or you will be getting stuck everywhere year round. Snow tires are really only a band-aid, with such a low profile the car will literally get stuck IN the snow. Lol.
I have family up in Mass, and even though they're in relatively urban areas (Woburn, Wakefield, and Newton) there's no way I would have a car like this in the dead of winter. It just doesn't work.
I would change the oil and oil filter, check the anti freeze.
Fill up the tank 3/4 full and add a fuel stabilizer.
Ensure that the rag top is completely dry, lower it and put on the hard top.
Leave the windows slightly open and cover the car.
You could also lift the car so the weight are not on the tires.
Than I would remove the battery and leave it with a triggle charger on. (Just remember to reset all functions when reinstalling it in the spring).
Good luck.
Store it with a fresh oil change. Old oil is more acidic than new oil. Your engine will store better with new oil since it will have the best anti-corrosion inhibitors.
I'd coat the frame with this stuff to prevent rust: AMSOIL - MP Heavy Duty Metal Protector (AMH)
If you like your tires, put the car up on jack stands and lower the tire pressure to 5 psi. That will prevent flat spots but maintain the bead seal. If you have Nitrogen in your tires it will not prevent flat spots.
I'd also recommend changing all driveline fluids before storage for the reasons I mentioned above. Old fluid has a small percentage of moisture, usually due to condensation. Fresh oils and lubricants will protect your driveline components the best. <--took to the dearlerhip to do it, they thought I was nuts until I told them how long it was getting stored for.
It took my husband and I about 4 hours of team work and 2 bottles on Pinot Noir to get it done but well worth it. I am sure that are hundreds of folks out there who will disagree with what I did and may even have their own suggestions, either way it is up to you.
