SL/R129: Hood going up but not down!
The hardtop mechanism works fine, the rollbar fine, the windows also close fine with the hood switch. It seems when the button is pressed to lower the hood, the motors make the same action as if when closing.. the windows do not lower either. The hood lowers manually fine, there are no obstructions. All fuses are OK, not sure if hydraulic fluid is OK though, where do I find the reservoir?
Any help would be greatly appreciated!
You probably need to reset the syncronization of the control module. Go to the Sticky's in benzworld.org/forums
On your car that is done with the red convertible top switch on your console.
Look for the directions. You will need to jump connections in the diagnostic plug, which is located near firewall on passenger side. As I said before, go to the other web site.
