SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Remove '96 SL500 Shift
Old Mar 22, 2010 | 12:52 PM
thompson12001's Avatar
sl 500
Hi. Easy problem but I'm not sure where to start. I am having difficulty removing my shifter on my '96 r129. Do I need to remove the entire shaft to remove the knob or will it twist off? Any input would be appreciated. Thanks
Old Mar 22, 2010 | 01:43 PM
Bernie C's Avatar
S320 CDI
Hi
There is a ferrule underneath the gear knob which needs to be turned about 90 degrees - this then loosens the knob which should then slide off with a bit of slight twisting motion - putting it back on is the reverse of this.
Hope this helps
Bernie
