SL/R129: looking to purchase sl
You can start researching the two different models here,
https://mbworld.org/forums/sl-class-...materials.html
If you have a local to you Qualified Independent(non-dealer) Technician, go make him your 'new best friend'. Discuss these two models with him.
A good mechanic, who understands the complexity of a R 129 is important. Good luck finding the cherry.
You didn't say how mechanically inclined you are. I've done a lot of work on Japanese and U.S. cars and trucks (advanced DIY), but hadn't touched an MB. Using the information I found this forum and benzworld.org I knew what to look for, and how to fix what I found wrong. I was able to knock more than $2k off the dealer's price by pointing out what was wrong with the car and the MB dealer's cost to repair (they took the car to an MB Dealer to verify). I did the work myself for under $600.
When you start looking seriously pay particular attention to the top cylinders (11 on my '98) - know where they are, run the top up and down at least 3 times and check each for leaks. The MB dealer price to replace all is in the $4k neighborhood. You can do it yourself for under $600 if all were leaking by using the sources you'll find in the forums. Similarly, look for things like cracking front strut mounts (parts are $60 each, and it is a :30 DIY), drive shaft flex joints, front & rear suspension bushings, etc. Source your parts carefully on the internet and you can save a bundle.
When you get down to "the car", pay $150 to have an MB dealer or indy with a Star diagnosis set-up scan all the computer controlled systems (there are a lot on these cars and they are sensitive to things like battery chargers and jump starting).
Good hunting and good luck...
The Active Dampening shock system on my friends 1998 cost $3,000 to repair - I decided against the V12 when I saw his car had 3 different warning lights lit up! Ouch. Big bills.
My 1991 Sl 500 needs $750 of work and that's little by comparison.
They are not just expensive to purchase - but expensive to keep up.
Off the top of my head, I've noticed the 500's have slightly better "off the line" performance where as the 600's have better performance once rolling. The 500's will (most likely) cost less to insure/maintain/fill with gas/etc than a 600.
In the end though, if I ever was going to buy another R129 (selling my SL500 because I am sick of being stuck in a two door, two seater car), it would definitely be a 600. The 500 was fun while it lasted, but you just don't get the feeling of all the torque and power the 600 has to offer.
Ricky
