SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: cleanning back window
Old Aug 16, 2010 | 02:04 PM
jimbo409's Avatar
2004 sl
What is the best way to clean the back window on a 500sl It is yellow is there any way io clean to clean this. Also does anyone know where to buy the hood insulation for this car. Thanks Again Jimbo
Old Aug 16, 2010 | 10:21 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
yellow tint and glue
two excellent questions. While some heat blankets have clips, most use a high heat spray glue. the dealer or parts dealer can sell. I used partsbin for the foam pad. For the convertible top plastic back window I tried cleaner and vinegar-water but really got a clear window with the convertible top window replacement. Also had the head liner replaced too
Old Aug 17, 2010 | 10:12 AM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
Source for hood pads... www.autohausaz.com
Plastic window cleaner....Meguiar's PlastX cleaner conditioner. Keep in mind that if your windows are too far gone, i.e. yellow turning to brown on the edges, plan on replacing the plastic as nothing can completely reverse extreme sun damage.
Bob
Old Aug 17, 2010 | 11:16 AM
nilop's Avatar
2001 SL500, '09 Murano, '04 Honda
Keep in mind that most times you can't simply just replace the plastic window but rather you will need to replace that entire section of the convertible top. I have an '01 SL500 and the top is actually two pieces so if your top is not that old, you can probably just replace the back portion but if its old, you'll need to replace both as the front portion will likley get ruined when they try and take off the back section. I just replaced my entire top this past year and was able to get it done for $1,600. Good luck.
