SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Soft Top wont retract completely
Old Oct 9, 2010 | 11:28 PM
meratzloff's Avatar
1999 SL 500
99 SL500 - 50K miles.
Top mechanism has been intermittent for a while now. Now it wont open all the way (get's stuck at the top). Here is the sequence:
1) Windows roll - normal
2) back hatch opens - normal
3) back window folds ip - normal
4) top winshield actuators release - normal
5) freezes - not normal
I can hear the actuator pulsing every second trying to catch it to close.
It has done this intermittently for several years but usually opens when i cycle it a few times. Now it freezes every time.
Closes OK though.
Please advise. Thanks! Mitch
Old Oct 10, 2010 | 08:39 PM
RWDvelocity's Avatar
Volvo & Mercedes
I am by no means an expert, but I'll give it a try. The front latches have a known problem to leak hydraulic fluid and subsequently fail to release. This may have been what happened. Hopefully someone more knowledgeable can lend this expertise, but you (or the dealership) can check the fluid reservoir in the back to determine if there has been some loss.
Old Oct 10, 2010 | 10:00 PM
meratzloff's Avatar
1999 SL 500
Thanks RWD. Front actuaries release... Which is good. Checked hyd fluid level and is at min. See no leaks. Will go to dealer for fluid this week.
Old Oct 11, 2010 | 08:52 PM
Rocco Vespe's Avatar
2003 SL500
Angry top problems
sounds like low fluid level.add fuid and try again
Old Oct 15, 2010 | 10:34 AM
meratzloff's Avatar
1999 SL 500
Topped off hyd fluid. No change. Still gets stuck half way (hyd pulses when suck half way). Any help is appreciated.
Old Oct 15, 2010 | 11:12 AM
meratzloff's Avatar
1999 SL 500
No visible leaks anywhere either. Only held a few ounces. Frustrating
Old Oct 15, 2010 | 12:14 PM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
Mitch,
The moderator of the 129 Forum at Benzworld.org pulled together a large set of threads about the functioning of the various parts of the top system, how to diagnose and how to fix. Here's the link...
http://www.benzworld.org/forums/r129...ml#post2419223
Bob
Old Oct 18, 2010 | 11:03 AM
degeja's Avatar
2016 E350 Sedan SPort
resync windows if top preezes being raised
My 1996 SL320 froze periodically when raising the soft top.
resynced the windows and problem has gone away.
Followed sync procedure in manual but held up button 10 seconds instead of the 2 seconds the owners manual--
in quiet garage--heard a click after about 8 seconds.
