SL/R129: Engine & Transmission mounts?
I have another question, I was thinking of changing the transmission fluid. What do you recommend for the fluid? Do you I just need the fluid, is there a filter? Thanks for your help.
http://www.rmeuropean.com/
you may end up at the Dealer for this one. As far as the fluid, the info is in your owners manual. If you decide to change it, get the filter and pan gasket, and pick up a pan magnet at NAPA et.al. and install it when you change the fluid. Remember to drain the torque convertor and trans cooler and lines to get it all out before refilling. IMO, this is a job for a transmission tech experienced with this car.
