SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Air-con problem 1995 SL500
Old Mar 19, 2011 | 04:28 PM
rogerthat's Avatar
SL500 (1995), 230E (1988)
Hi all, I just got myself a 1995 SL500 and the air con has just packed up.
When I press either Automatic or any of the fans 1 to 4 buttons, no air blows out from any of the vents but I could hear noises inside the dashboard.
Also, I found one of the tubes in the engine completely iced up when the car is fired up with the air con switch on (but no air blowing).
I checked the fuses and they were okay.
Can I get some advise on the probable issues?
Thanks!
Old Mar 29, 2011 | 08:39 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
Sounds like your evaporator fan has bitten the dust or the bracket that holds the motor has failed and allowed the squirrel cage to hit something and bind up.
Old Mar 30, 2011 | 11:07 AM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
Thanks!
Rogerthat, Welcome to the forum. When you get a moment, complete your profile with location.
Lee could be absolutely right in his comments about the evaporator. My personal preference is to run the on-board diagnostics built into the Climate Control unit... See https://mbworld.org/forums/e-class-w...ble-shoot.html
Your symptoms could be an evaporator temp sensor or any number of other components...the diagnostics will set you in the right direction. Good Hunting-
Bob
Old Mar 31, 2011 | 12:32 AM
rogerthat's Avatar
Ok got it. The mechanic said the blower motor needed replacement plus a new resistor.
Will be getting the car back later today. Will update
Old Apr 6, 2011 | 01:08 PM
rogerthat's Avatar
My mechanic changed the blower and the problem is solved.
