SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Difficult to start when engine is hot
Old Apr 3, 2011 | 03:50 AM
rogerthat's Avatar
SL500 (1995), 230E (1988)
My SL500 seems to have difficulty starting when the engine is hot. Very easy to start when cold though. Anyone had similar issues?
Old Apr 3, 2011 | 09:55 AM
SLCL's Avatar
CL55, SL500, E350
If you need help, you should describe more details the symptoms. Also, the mileage and model year of your SL500 should also be helpful.
Without all those, my guess is either CPS or fuel pump/sensor.
Old Apr 3, 2011 | 02:38 PM
abiby's Avatar
82 380SL 96 SL500
If '90-'92 a failing fuel accumulator would be a good guess.
If it's a newer model I'd guess a sensor, but damned if I know which one.
You did notice I said "guess"?
BTW, please add model year to your profile. It makes a BIG difference as there are major differences in models.
Old Apr 3, 2011 | 03:18 PM
ohlord's Avatar
Replace the
CPS crank position sensor. Takes all of 15 minutes
Old Apr 6, 2011 | 12:15 PM
rogerthat's Avatar
The car is with the mechanic as we speak. He reckons the difficulty in starting when the engine is hot is due to two faulty fuel valves so the 2 fuel valves needs replacement as there was evidence of fuel leak in that area. I should be getting the car back in a day or two so I will update again.
Old Jun 8, 2011 | 12:58 PM
jgardner808's Avatar
1992 500SL
Hello !
any update to your fix ?
thx
jg.
