SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: roll Bar
Old May 22, 2011 | 12:30 PM
rdutton007's Avatar
96 Mercedes 500SL
roll Bar
Roll bar down, will not go up.. Soft top goes up and down fine,, No warning lights. I can hear motor? running and roll bar moves a bit but will not go up.It is like the mechanism is not engaging completely. Tried all the solutions, like holding button for 20 seconds and such, still no resolution. Did not check fluid level since the top works fine. Need some help
Old Jul 8, 2011 | 08:39 AM
degeja's Avatar
2016 E350 Sedan SPort
try disconnecting the battery for 30 minutes- reconnect.
then reset the windows per the manual.
Old Jul 20, 2011 | 10:20 AM
lector's Avatar
1997 sl500 83 Elcamino 05 Caddie
Make sure
That you have the radio code handy before you disconnect the battery.
Old Jul 25, 2011 | 04:55 PM
Russell Ormerod's Avatar
not a merc
check fault codes first
