SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: driver seat stopped working
Old Aug 7, 2012 | 02:03 PM
Big Reid's Avatar
1998 SL 500
The drivers seat on my 1998 SL 500 stopped working after i vacuumed.I moved the seat all the way forward then all the way back & then nothing.Ive checked the fuses & their all good. Whats next?
Old Aug 11, 2012 | 10:12 AM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
Did you check the plug under the seat? If connected, check the door panel connection. After all the continuity checks then I would use the other seat controller with the non functioning seat. The plug system is identical. There are videos for seat pad removal, a couple of 10mm bolts, as I recall!??
Good luck. Where in the world are you?
Old Aug 13, 2012 | 06:10 PM
Big Reid's Avatar
1998 SL 500
I am in Fayetteville GA I will try what you said I'm trying to locate that video for seat removal SRHsl600
Old Aug 13, 2012 | 06:12 PM
Big Reid's Avatar
1998 SL 500
Is it a you tube video?
Old Aug 19, 2012 | 10:24 AM
SRHsl600's Avatar
YouTube Tamango's channel. Benzworld has a sticky section that has additional videos as well as owner's advise like MBworld.
