SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: engine spins but won't fire up
Old Nov 22, 2012 | 10:56 AM
albrazeagle's Avatar
1990 sl500 mercedes benz
I have 1990 sl500 I recently bought 3-weeks ago that won't start. I check the spark plugs and tried to see if there is spark came out when I crank the engine but, there's no spark coming out. I tried to replace the camshaft and crankshaft sensor but, still there's no sign of spark on the plugs.
Please, help!
Old Nov 23, 2012 | 06:59 AM
afrts's Avatar
1995 SL320
Car won't start
Do a Voltage loss test on your battery..if there is a voltage loss..then go thru and clean the contacts on the battery, Starter, Alternator and the Ground Strap from the engine to the chassis. Then try and start the car.
Old Nov 24, 2012 | 11:18 PM
Hi!
I had tried the cleaning all the contacts starting from the battery positive and negative poles, all the engine and body grounds, but still it cranks but, it won't fire up. Thanks, afrts, for your
concern. I really appreciate it. I still digging deeper to these mazed.
Old Nov 26, 2012 | 04:10 PM
afrts's Avatar
1995 SL320
What kind of voltage are you getting at the Crank Sensor while turning over your engine..?
