SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: OutsideTemperature sensor
Old Dec 1, 2012 | 12:09 AM
crangip's Avatar
1991 Mercedes Benz 300 SL
I just replaced the front bumper on my 91 300 SL. When the body shop painted and installed the new bumper the indicator on the dash that tells the outside temperature was not displaying the temp. Can anyone tell me if that is a thing I can fix myself if so, what is the procedure?
Thank you.
Old Dec 1, 2012 | 09:23 AM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
crangip,
The outside temp sensor 'should be' mounted into a friction-fit bracket found on the front bumper, lower left/driver's side, in the vertical slats. The fitting is black, around 3x3". Near the center of the bracket you should see a small sensor tip protuding.
If the sensor and fitting are there, then the problem is a broken wire that needs to be spliced. Take the car back to the shop and let them do it; they broke it. It's very very common for shops to do this.
If either the sensor and/or the fitting are missing, it means the shop forgot to reinstall it in the vertical slats and it's dangling somewhere in the front of the car. Once again, take it back to the shop and let them install it for you.
Old Dec 1, 2012 | 12:20 PM
crangip's Avatar
Thanks for this. The sensor was out back in to the bumper but it was originally painted the color of the car, signal red.
I have to take the. Car back to have them paint the wheels and to install a new hood pad. So I will have them fix it then. When i was laying around with the sensor i didnt notice anything wrong- broken or frayed wire.Again thank you
